Hi Sirs/Ma’ams,
I am new here in InfinityFree hosting, I am also new in making webpage and uploading it.
Can you help me to work with my webpage? What first thing to do?
e.g., Step1: Go to Control Panel/File Manager… etc…
Thank you in advance!
Hi Sirs/Ma’ams,
Continueing your path. Then click on upload button on button. Then click on upload files to upload your files.
If you want to upload a folder with its files. Click on upload folder
I suggest you use a FTP client to do that, if you’re working with multiple files:
https://infinityfree.net/support/how-to-upload-files-with-ftp/
because file managers are sometimes buggy.
And, you must upload your website files in the htdocs/ folder!
Seen that you uploaded all the files on My Tutorial Webpage/Files inside the htdocs folder you need to access it by visiting yourdomain/My%20Tutorial%20Webpage/Files/ on your browser. If you want to access it only by visiting yourdomain/, you should move the files inside htdocs.
Ok, this is noted.
Already working. Thank you!
Kindly, close this thread. Resolved!
