Hello!
So I’m recently new to infinityfree and I don’t understand how to connect my php code to the MySQL database.
If you know how to do it please reply ![]()
Thanks!
Hello!
Thanks!
Knowledgebase to the rescue!
The PDO library (I recommend this one)
Hey!
Thanks for the response, but I want to say that I already have a working code from my localhost, I just can’t find out on how to connect the MySQL, since I have never worked with MySQL on a host program!
Then just replace your localhost credentials with your production ones (From IF). You can find them in the client area.
Also, make sure to specify a database table name, it is required on free hosting.
