PHPMailer stopped working without doing anything... Problem?
Hi there
i’m hosting a website on infinityfree for a year now and used PHPmailer for a contactform.
Since a couple of days, PHPmailer stopped working and i get the next error code.
Did infinityfree blocked something? Did something changed?
Tried to update , but doesn’t help.
Best Regards
Tom
2022-02-01 11:38:29 Connection: opening to smtp.live.com:587, timeout=300, options=array()
2022-02-01 11:39:32 Connection failed. Error #2: stream_socket_client(): unable to connect to smtp.live.com:587 (Connection timed out) [/home/vol14_2/epizy.com/epiz_28082738/htdocs/PHPMailer/src/SMTP.php line 389]
2022-02-01 11:39:32 SMTP ERROR: Failed to connect to server: Connection timed out (110)
SMTP connect() failed. Troubleshooting · PHPMailer/PHPMailer Wiki · GitHub
Mailer Error: SMTP connect() failed. Troubleshooting · PHPMailer/PHPMailer Wiki · GitHub
I think you may need to look at your code again. If I am correct, you should connect to smtp.outlook.com, not live.com.
Using SMTP through PHPMailer is certainly supported here, I use it myself.
Hi WackyBlackie
Thats weird. It have been working for a year & didn’t change anything in the script.
I tried it and now it works again.
How weird is this?
Thanks mate!
I think Microsoft just removed SMTP support on live.com.
Yes, they indeed changed their smtp information.
Thanks for the information Guys! It works!
