An unexpected error occurs while sending mails from website.
I’m using a custom php script configured with phpmailer but it’s not working. As of my knowledge infinityfree supports phpmailer only. Here’s my script:
PHPMailer Initialization
use PHPMailer\PHPMailer\PHPMailer;
use PHPMailer\PHPMailer\Exception;
require 'phpmailer/src/Exception.php';
require 'phpmailer/src/PHPMailer.php';
require 'phpmailer/src/SMTP.php';
Receiver's Email
$toemails = array();
$toemails[x] = array(
'email' => '[email protected]', // Your Email Address
'name' => 'Jay' // Your Name
Sender's Email
$fromemail = array(
'email' => '[email protected]', // Company's Email Address (preferably currently used Domain Name)
'name' => 'New Entry - Contact Form' // Company Name
reCaptcha
// Add this only if you use reCaptcha with your Contact Forms
$recaptcha_secret = '*******************************************';
$mail = new PHPMailer();
/* Add your SMTP Codes after this Line */
$mail->SMTPDebug = 0; // Enable verbose debug output
$mail->isSMTP(); // Set mailer to use SMTP
$mail->Host = 'smtp.gmail.com'; // Specify main and backup SMTP servers
$mail->SMTPAuth = true; // Enable SMTP authentication
$mail->Username = '[email protected]'; // SMTP username
$mail->Password = '***********'; // SMTP password
$mail->SMTPSecure = 'tls'; // Enable TLS encryption,
$mail->Port = 587;
// End of SMTP
Form Messages
$message = array(
'success' => 'We have <strong>successfully</strong> received your Message and will get Back to you as soon as possible.',
'error' => 'Email <strong>could not</strong> be sent due to some Unexpected Error. Please Try Again later.',
'error_bot' => 'Bot Detected! Form could not be processed! Please Try Again!',
'error_unexpected' => 'An <strong>unexpected error</strong> occured. Please Try Again later.',
'captcha_invalid' => 'Captcha not Validated! Please Try Again!',
'captcha_error' => 'Captcha not Submitted! Please Try Again.'
SPAM Protection Settings
$spam_keywords = array(
'viagra',
'cialis',
'levitra'
$allowed_urls = 1;
Form Processor
if ($_SERVER['REQUEST_METHOD'] == 'POST') {
$prefix = !empty($_POST['prefix']) ? $_POST['prefix'] : '';
$submits = $_POST;
$botpassed = false;
$message_form = !empty($submits['message']) ? $submits['message'] : array();
$message['success'] = !empty($message_form['success']) ? $message_form['success'] : $message['success'];
$message['error'] = !empty($message_form['error']) ? $message_form['error'] : $message['error'];
$message['error_bot'] = !empty($message_form['error_bot']) ? $message_form['error_bot'] : $message['error_bot'];
$message['error_unexpected'] = !empty($message_form['error_unexpected']) ? $message_form['error_unexpected'] : $message['error_unexpected'];
$message['captcha_invalid'] = !empty($message_form['captcha_invalid']) ? $message_form['captcha_invalid'] : $message['captcha_invalid'];
$message['captcha_error'] = !empty($message_form['captcha_error']) ? $message_form['captcha_error'] : $message['captcha_error'];
SPAM Protection
function spam_keyword_check($submitted, $spamwords)
if (is_array($submitted)) {
return false;
if (!is_array($spamwords)) $spamwords = array($spamwords);
foreach ($spamwords as $spamstring) {
if (($position = stripos($submitted, $spamstring)) !== false) return $position;
return false;
function spam_url_check($submitted)
return false;
$pattern = "/(http|https)\:\/\/(www\.)?[a-zA-Z0-9\-\.]+\.[a-zA-Z]{2,3}(\/\S*)?/";
if (preg_match_all($pattern, $submitted, $urls)) {
return count($urls);
return false;
foreach ($submits as $spam_submit) {
if (spam_keyword_check($spam_submit, $spam_keywords) || spam_url_check($spam_submit) > $allowed_urls) {
// A successful message is displayed to the submitter that makes him think that the Form has been sent so that he cannot modify the keywords to prevent SPAM
echo '{ "alert": "success", "message": "' . $message['success'] . '" }';
exit;
reCaptcha
if (isset($submits['g-recaptcha-response']) && !isset($submits['h-captcha-response'])) {
$recaptcha_data = array(
'secret' => $recaptcha_secret,
'response' => $submits['g-recaptcha-response']
$recap_verify = curl_init();
curl_setopt($recap_verify, CURLOPT_URL, "https://www.google.com/recaptcha/api/siteverify");
curl_setopt($recap_verify, CURLOPT_POST, true);
curl_setopt($recap_verify, CURLOPT_POSTFIELDS, http_build_query($recaptcha_data));
curl_setopt($recap_verify, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($recap_verify, CURLOPT_RETURNTRANSFER, true);
$recap_response = curl_exec($recap_verify);
$g_response = json_decode($recap_response);
if ($g_response->success !== true) {
echo '{ "alert": "error", "message": "' . $message['captcha_invalid'] . '" }';
exit;
$mail->Subject = !empty($submits['subject']) ? $submits['subject'] : 'Form Response from your Website';
$mail->SetFrom($fromemail['email'], $fromemail['name']);
if (!empty($replyto)) {
if (count($replyto) > 1) {
$replyto_e = $submits[$replyto[0]];
$replyto_n = $submits[$replyto[1]];
$mail->AddReplyTo($replyto_e, $replyto_n);
} elseif (count($replyto) == 1) {
$mail->AddReplyTo($replyto_e);
foreach ($toemails as $toemail) {
$mail->AddAddress($toemail['email'], $toemail['name']);
All Processing for Fields starting
$underscore = array();
foreach ($submits as $name => $value) {
if (strpos($name, '_') === 0) {
$underscore[] = $name;
$unsets = array('prefix', 'subject', 'replyto', 'template', 'html_title', 'message', 'autoresponder', 'ar_subject', 'ar_title', 'ar_message', 'ar_footer', $prefix . 'botcheck', 'g-recaptcha-response', 'h-captcha-response', 'force_recaptcha', $prefix . 'submit');
$unsets = $unsets + $underscore;
foreach ($unsets as $unset) {
unset($submits[$unset]);
$fields = array();
if (empty($value)) {
continue;
$name = str_replace($prefix, '', $name);
$name = function_exists('mb_convert_case') ? mb_convert_case($name, MB_CASE_TITLE, "UTF-8") : ucwords($name);
if (is_array($value)) {
$value = implode(', ', $value);
$fields[$name] = nl2br(filter_var($value, FILTER_SANITIZE_SPECIAL_CHARS));
$files = $_FILES;
foreach ($files as $file => $filevalue) {
if (is_array($filevalue['name'])) {
$filecount = count($filevalue['name']);
for ($f = 0; $f < $filecount; $f++) {
if (isset($_FILES[$file]) && $_FILES[$file]['error'][$f] == UPLOAD_ERR_OK) {
$mail->IsHTML(true);
$mail->AddAttachment($_FILES[$file]['tmp_name'][$f], $_FILES[$file]['name'][$f]);
} else {
if (isset($_FILES[$file]) && $_FILES[$file]['error'] == UPLOAD_ERR_OK) {
$mail->AddAttachment($_FILES[$file]['tmp_name'], $_FILES[$file]['name']);
$response = array();
foreach ($fields as $fieldname => $fieldvalue) {
if ($template == 'text') {
$response[] = $fieldname . ': ' . $fieldvalue;
} else {
$fieldname = '<tr>
<td style="font-size: 16px; line-height: 24px; font-weight: bold; padding: 0 0 5px 0;" align="left">' . $fieldname . '</td>
</tr>';
$fieldvalue = '<tr>
<td style="font-size: 16px; line-height: 24px; color: #777777; padding: 0 15px 30px 0;" align="left">' . $fieldvalue . '</td>
</tr>';
$response[] = $fieldname . $fieldvalue;
$referrer = $_SERVER['HTTP_REFERER'] ? '<br><br><br>This Form was submitted from: ' . $_SERVER['HTTP_REFERER'] : '';
$html_before = '<table border="0" cellpadding="0" cellspacing="0" height="100%" width="100%" bgcolor="#eeeeee" style="width: 100%; height: 100%; padding: 50px 0 50px 0;">
<tr>
<td align="center" valign="top">
<table border="0" cellpadding="0" cellspacing="0" width="84%" bgcolor="#ffffff" style="width: 84%;">
<tr>
$html_after = '</td>
</tr>
</table>
</td>
</tr>
</table>';
$body = implode("<br>", $response) . $referrer;
} else {
$html = $html_before . '<!-- / Header -->
<table border="0" cellpadding="0" cellspacing="0" width="84%" style="width: 84%;">
<tr>
<td style="padding: 30px 0 30px 0; border-bottom: solid 1px #eeeeee; font-size: 30px; font-weight: bold; text-decoration: none; color: #000000;" align="left">
' . $html_title . '
</td>
</tr>
</table>
<!-- / Sub-Header -->
<table border="0" cellpadding="0" cellspacing="0" width="84%" style="width: 84%; padding: 60px 0 30px 0;"">
' . implode('', $response) . '
</table>
<!-- / Footer -->
<table border="0" cellpadding="0" cellspacing="0" width="100%" align="center">
<tr>
<td align="center">
<table border="0" cellpadding="0" cellspacing="0" width="84%" align="center" style="border-top: 1px solid #eeeeee; width: 84%;">
<tr>
<td style="color: #d5d5d5; text-align: center; font-size: 12px; padding: 30px 0 30px 0; line-height: 22px;">' . strip_tags($referrer) . '</td>
</tr>
</table>
</td>
</tr>
</table>
' . $html_after;
$body = $html;
<tr>
<td style="font-size: 16px; line-height: 26px; color: #777777; padding: 0 15px 30px 0;" align="left">' . $ar_message . '</td>
</tr>
</table>
<!-- / Footer -->
<tr>
<td align="center">
<tr>
<td style="color: #d5d5d5; text-align: center; font-size: 12px; padding: 30px 0 30px 0; line-height: 22px;">' . $ar_footer . '</td>
</tr>
</table>
</td>
</tr>
</table>
' . $html_after;
$autoresponder->MsgHTML($ar_body);
$autoresponder->CharSet = "UTF-8";
$mail->MsgHTML($body);
$mail->CharSet = "UTF-8";
$sendEmail = $mail->Send();
if ($sendEmail == true):
if ($autores && !empty($replyto_e)) {
$send_arEmail = $autoresponder->Send();
else:
echo '{ "alert": "error", "message": "' . $message['error'] . '<br><br><strong>Reason:</strong><br>' . $mail->ErrorInfo . '" }';
endif;
} else {
echo '{ "alert": "error", "message": "' . $message['error_unexpected'] . '" }';
