Here’s what I found. The two earlier vulnerabilities (CVE-2026-109618 and CVE-2026-109619, the PHP2Shell ones) were fixed on InfinityFree. An accepted answer in another topic says the update has been rolled out to everyone, and it links the status page for it:
I couldn’t find anything on the forum about CVE-2026-115560. So I can’t tell you whether InfinityFree and iFastNet know about it, whether our servers are affected, or whether a patch is planned. Your post says it only affects unusual session configurations, so I can’t say whether it applies here either.
Could you link the PHP advisory for CVE-2026-115560, for example on php.net? Then anyone reading can check which PHP versions and which session settings it covers.
The issue can onlyoccur under an unusual combination of configuration and application code.An application must set session.serialize_handler to php_binary or php_serialize in its configuration and then switch it to php at runtime with ini_set() before calling session_start(). Session upload progress must also still be enabled.
From a quick test I did, `session.serialize_handler is on php by default instead of php_binary or php_serialize, so it should be unaffected.
