CJcorp (CJcorp.epizy.com)
Hi I am making an application for android phone which uses infinityfree.net MySql database to store user data i need help in design a php script through which I can post query about Insert, read, delete and update database data from my application can any one help me regarding this I tried with a php script but it’s not working
Here is thee script
<?php
//DATABSE DETAILS//
$DB_ADDRESS="sql306.ultimatefreehost.in";
$DB_USER="ltm_24835408";
$DB_PASS="HIDDEN BY MOD";
$DB_NAME="ltm_24835408_MovieHouseHD";
//SETTINGS//
//This code is something you set in the APP so random people cant use it.
$SQLKEY="MovieHouseHD";
/************************************CONFIG****************************************/
//these are just in case setting headers forcing it to always expire
header('Cache-Control: no-cache, must-revalidate');
error_log(print_r($_POST,TRUE));
if( isset($_POST['query']) && isset($_POST['key']) ){ //checks if the tag post is there and if its been a proper form post
//set content type to CSV (to be set here to be able to access this page also with a browser)
header('Content-type: text/csv');
if($_POST['key']==$SQLKEY){ //validates the SQL key
$query=urldecode($_POST['query']);
if(get_magic_quotes_gpc()){ //check if the worthless pile of crap magic quotes is enabled and if it is, strip the slashes from the query
$query=stripslashes($query);
$conn = new mysqli($DB_ADDRESS,$DB_USER,$DB_PASS,$DB_NAME); //connect
if($conn->connect_error){ //checks connection
header("HTTP/1.0 400 Bad Request");
echo "ERROR Database Connection Failed: " . $conn->connect_error, E_USER_ERROR; //reports a DB connection failure
} else {
$result=$conn->query($query); //runs the posted query
if($result === false){
header("HTTP/1.0 400 Bad Request"); //sends back a bad request error
echo "Wrong SQL: " . $query . " Error: " . $conn->error, E_USER_ERROR; //errors if the query is bad and spits the error back to the client
} else {
if (strlen(stristr($query,"SELECT"))>0) { //tests if it's a SELECT statement
$csv = ''; // bug fix Undefined variable: csv
while ($fieldinfo = $result->fetch_field()) {
$csv .= $fieldinfo->name.",";
$csv = rtrim($csv, ",")."\n";
echo $csv; //prints header row
$csv = '';
$result->data_seek(0);
while($row = $result->fetch_assoc()){
foreach ($row as $key => $value) {
$csv .= $value.",";
echo $csv; //prints all data rows
} else {
header("HTTP/1.0 201 Rows");
echo "AFFECTED ROWS: " . $conn->affected_rows; //if the query is anything but a SELECT, it will return the number of affected rows
$conn->close(); //closes the DB
} else {
echo "Bad Request"; //reports if the secret key was bad
} else {
echo "Bad Request";
