Could you post the lines of your PHP code that set up the connection, with the password removed? I need to see the hostname, database name and username your script uses, and whether it’s the PDO DSN or a config file.
Your control panel host is sql208, and the database on your account has a name ending in la_anadidura_dios after the account prefix. I’d like to compare those against what your code has, character by character. I also need to know whether the script is running on your InfinityFree site, or somewhere else such as your own computer or another host.
I’m asking about the last point because of what the knowledge base says about connections. InfinityFree databases can only be reached from inside an InfinityFree hosting account, not from other locations. It also says the hostname must be the one from your control panel’s MySQL Databases section, never localhost.
The article doesn’t list “Connection refused” as one of its examples, so I can’t say yet which of these is the cause.
The connection is made with PDO using a DSN. The relevant code is:<?php
$host = getenv(‘DB_HOST’) ?: ‘127.0.0.1’;
$database = getenv(‘DB_NAME’) ?: ‘la_anadidura_dios’;
$username = getenv(‘DB_USER’) ?: ‘root’;
$password = getenv(‘DB_PASSWORD’) ?: ‘’; // redacted
$dsn = “mysql:host={$host};dbname={$database};charset=utf8mb4”;
$pdo = new PDO($dsn, $username, $password, [
PDO::ATTR_ERRMODE => PDO::ERRMODE_EXCEPTION,
]); My .env values are:
DB_HOST=sql208.infinityfree.com
DB_NAME=if0_43408642_la_anadidura_dios
DB_USER=if0_43408642
DB_PASSWORD is set but redacted.
The exact error returned by the test is SQLSTATE[HY000] [2002] Connection refused. The database and tables are visible in phpMyAdmin. Could you help identify why the connection is refused?
The specific code tries to read the DB_HOST environment variable, and if it’s not set or empty, use 127.0.0.1.
But using 127.0.0.1 would cause that Connection Refused error. So I suspect that getenv('DB_HOST') is not actually returning the configuration from your .env file.
A simple line saying var_dump(getenv('DB_HOST')); just before the database connection will tell you whether that’s the case.
