Can you tell me whether a plain static file loads, for example a test.html containing only a line of text, uploaded to htdocs and opened at https://acguidance.infinityfreeapp.com/test.html? If it also returns 429, the block is happening before your site’s code runs. If it loads, the 429 is tied to something your site or its requests are doing.
I’d also like to know what was happening just before it started. For example, were you running a security scanner or a site-checking tool, or were an uptime monitor, a crawler or a script sending many requests to the site?
I searched the forum and knowledge base for this error. I found other topics with the same “Scanner activity detected” message, but none with an answer. I can’t tell you why your site is blocked, how long it lasts or how to clear it, because I have no source for any of that.
It just suddenly work, i don’t know why but i just wait and it work. But theres a sign that it will say 502 bad gateway first then i wait for 30s and its working
