The page /smartattend_plus/improvement_plan.php opens normally when accessed directly and also opens through a link on a test PHP page inside the same folder.
However, navigating to the exact same page through my website’s sidebar consistently redirects to:
Control panel: InfinityFree Client Area / File Manager
Additional details: The affected PHP page opens normally when accessed directly and through a test PHP page in the same directory. However, navigation through the website sidebar consistently redirects to InfinityFree’s 403 error page.
I have tested absolute URLs, relative URLs, JavaScript navigation, and a PHP redirect. The issue persists.
Could you copy the exact link the sidebar uses (the href, or the address you land on in the browser after the redirect)? The page itself loads fine, so the difference has to be in what the sidebar sends. I need to see that to tell what’s different.
The one thing I found that matches is that the server blocks some keywords in a URL. The article lists “chat” and “includes” and says it applies to the whole URL, not just the file name. It could apply if the sidebar link has a query string, or a path or folder, containing one of those words. I can’t tell yet whether that’s your case.
Here’s the article on 403 errors, including the blocked keywords:
Your website demands a login for everything, so even with what we can check there’s nothing we could check. The said link redirects me to the login page.
