Opencart/PrestaShop problem
Hi,
Firstly I try to install PrestaShop but it’s showing error about MySQL that length can be max 1000 bites or something like that.
And secondly I installed opencart, but I can’t log in to administration(password and username are correct) it still redirect me to log in section. Last thing I add some product to cart, but after clicking to basket to order… It’s deleted, and this happend to every product that I add there.
Why is this happening? :confused:
Current version of Prestashop is not supported on free hosting.
You can downgrade to lower version of Prestashop or upgrade to premuim hosting
As for OpenCart, this should answer your question…
THANK YOU ! IT WORKS great.
