Opencart Issue
epiz_26271091
Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/request.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/response.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/db.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/db/mysqli.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/session.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/session/db.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cache.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cache/file.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/url.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/language.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/document.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/customer.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/currency.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/tax.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/weight.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/length.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/cart/cart.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/encryption.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : is_file(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/modification/system/library/openbay.php) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/startup.php on line 62 Warning : fopen(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/logs/openbay.log) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/library/log.php on line 22 Warning : fopen(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/logs/openbay.log): failed to open stream: Operation not permitted in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/library/log.php on line 22 Warning : fopen(): open_basedir restriction in effect. File(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/logs/error.log) is not within the allowed path(s): (/php_sessions:/tmp:/var/www/errors:/usr/share/pear:/home/vol5_8/epizy.com/epiz_26271091/htdocs) in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/library/log.php on line 22 Warning : fopen(/home/vol5_8/epizy.com/epiz_26271091/ocartdata/storage/logs/error.log): failed to open stream: Operation not permitted in /home/vol5_8/epizy.com/epiz_26271091/htdocs/system/library/log.php on line 22
After installing Opencart via Softaculous the client page seems to be but I doubt that is the landing page of opencart and also the admin page seems to be having problems of some sort. (see errors above).
Is there anything that I need to do to get the website running? Thanks!
It’s because opencart requires some of files to be outside root folder (htdocs), while we don’t allow files outside htdocs to be accessed.
In short you cannot host this app here.
If opencart as you’ve said that it can’t be hosted. What would you recommend hat will work?
It depends what type of shop. What are you selling?
Technically not into selling, just promoting and marketing products with e-coupons and links to the store.
I just need to show what products and/or services that I’m promoting or marketing together with the information and link to claim the coupon and/or discount… Basically I don’t need the checkout cart functionality.
I guess WordPress would suit your needs then?
I guess will try that one out… is there any other app other than wordpress but similar to opencart that you can recommend?
WordPress is the best I know of @anon16418094 . Also @anon19508339, don’t say what I think your gonna say.
Will try Wordpress then… thanks a lot for helping out.
No problem. If your problem is solved, please mark the answer that solved your original question. I believe the to your original question is by @anon19508339:
You can take a look in the E-Commerce category in Softaculous. There are many more only store suites to be found in there, and they can be installed and tried quickly!
