Ns problem
is there any way to add a domain in control panel without ns redirection?
Not sure what you mean by that.
You must change the nameservers on your domain to connect it. Once it is connected, you may use other nameservers and an A record to show your site.
Technically, no - you have to switch your NS temporarily in order for your account to be created. This proves that you own the domain, effectively. You are free to switch it back once your account has been created - this is exactly what I did, if you look at my domain NS via a DNS lookup then you will see the NS are porkbun.com which is my domain registrar.
This is just the way that infinity run their account creation process. In most cases, if you change your NS to infinity, your account will be up and running within minutes (I think I had changed my NS, and five minutes later once I verified that my account was created and active - not pending - then I switched them back to porkbun).
So the quick answer to your question is, yes, you can add a domain without NS permanent redirection - just change them back again when you’re done.
