In my panel, option mySQLdatabase not appear my database, but work fine in the website.
why???, howto access with phpadmin???
Please try accessing this link directly one you login to vPanel: https://cpanel.epizy.com/panel/indexpl.php?option=pma
Not if I can enter the cpanel, but in the SQL section my database does not appear, although it is working, in this way I cannot open my database from the phpmyadmin…
I checked it and it’s the same issue, and the database database server, as this post from a few days ago:
I’ve asked iFastNet to fix it.
OK, now look and appear the database and work fine phpmyadmin.
Yep, the issue has been fixed now!
For anyone experiencing the same issue: the root cause has been identified and a fix has been implemented that should prevent this from happening again. That said, there may be accounts that still have this issue. If you do, please report it so it can be fixed for your account.
