None
Hey there, IF, I’m doxr. I’ve noticed there is no terminal or ssh or anything like that. I tried to get a Terminal by installing PHP and creating a “terminal” (password protected, for now, the password is “doxr” but I will change it once this topic is marked as solution). I used the CHMOD button but it didn’t seem to help. Just to know if the code is the problem or the server, I ran it on my own device: it worked fine, I got responses. How am I able to run any kind on command? My end goal here is to be able to host my own software instead of having to use Softalicious.
would something like uploading a nodejs proxy or a discourse forum (btw neat forum, I’ve never had it this good, lol) work? that’s my main goal. how do I use things like NPM or starting a webserver without a terminal?
Neither do we have Node.js or Docker (I believe this is the under-lying tech for Discourse forums).
For Node.js, you’ll need premium hosting.
For Dockers, even premium hosting don’t have it, and you’ll definitely need some VPSes / Dedicated servers. (Just wanted to say, while buying iFastNet shared premium is a good idea, buying VPSes from them isn’t )
