Username epiz_28494712
not access to control panel cpanel.epixy.com
Not Found
The requested URL /panel/modules/signout/index.php was not found on this server.
Are you opening it from the client area?
yes
Shd be https://cpanel.epizy.com
not function
Try cpanel.rf.gd your isp may be blocking epizy.com
That isn’t the valid client area address, it’s cpanel.epizy.com
cpanel.rf.gd works too
Just use your FTP account details to get into it.
This can happen if you are in the control panel while the account is being shut down. I see an account suspension logged around the same time, so that’s probably the reason.
