Not able to open website session issue
Username :- http://hkleaveportal.rf.gd/index.php
Warning : session_start(): open(/php_sessions/sess_8d539e4e7cdde7fef6072f73dc226cfb, O_RDWR) failed: No such file or directory (2) in /home/vol19_1/epizy.com/epiz_33050785/htdocs/index.php on line 2
Warning : session_start(): Failed to read session data: files (path: /php_sessions) in /home/vol19_1/epizy.com/epiz_33050785/htdocs/index.php on line 2
Make sure this is present
Dint understand can you please explain more
Screenshot your file directory structure
please help me to solve this because everything is working on my localhost and also other hosting but not here.
here only give such warnings for session
I do not see this php_sessions folder
here created folder but what should i put in it ?
How would I know?
You are the creator of your website…
this issue came when i hosted my website on infinity not with other hosting
You only tried on localhost
A lot of things can happen during migration.
Can you show the contents of index.php?
here
<?php include('includes/session.php'); session_start(); include('includes/config.php'); if(isset($_POST['signin'])) { $username=$_POST['username']; $password=md5($_POST['password']); $sql1 ="SELECT SUM(days) AS value_sum FROM data where emp_email ='$username'"; $re=mysqli_query($conn,$sql1); $row1=mysqli_fetch_assoc($re); $sum = $row1['value_sum']; if($sum >= 90){ $sql ="SELECT * FROM tblemployees where EmailId ='$username' AND Password ='$password'"; $query= mysqli_query($conn, $sql); $count = mysqli_num_rows($query); if($count > 0) { while ($row = mysqli_fetch_assoc($query)) { if ($row['role'] == 'Admin') { $_SESSION['alogin']=$row['emp_id']; $_SESSION['arole']=$row['Department']; echo ""; } elseif ($row['role'] == 'Staff' || $row['role'] == 'Management') { $_SESSION['alogin']=$row['emp_id']; $_SESSION['arole']=$row['Department']; echo ""; } elseif ($row['role'] == 'HR') { $_SESSION['alogin']=$row['emp_id']; $_SESSION['arole']=$row['Department']; echo ""; } else { $_SESSION['alogin']=$row['emp_id']; $_SESSION['arole']=$row['Department']; echo ""; } } } else{ echo ""; } } else{ echo ""; } } // $_SESSION['alogin']=$_POST['username']; // echo ""; ?>
<title>HK Leave Manager</title>
<!-- Site favicon -->
<!-- Mobile Specific Metas -->
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1">
<!-- Google Font -->
<!-- CSS -->
<link rel="stylesheet" type="text/css" href="vendors/styles/core.css">
<link rel="stylesheet" type="text/css" href="vendors/styles/icon-font.min.css">
<link rel="stylesheet" type="text/css" href="vendors/styles/style.css">
<!-- Global site tag (gtag.js) - Google Analytics -->
<script async src="https://www.googletagmanager.com/gtag/js?id=UA-119386393-1"></script>
<script>
	window.dataLayer = window.dataLayer || [];
	function gtag(){dataLayer.push(arguments);}
	gtag('js', new Date());
	gtag('config', 'UA-119386393-1');
</script>
<script src= "https://cdn.datatables.net/1.11.3/js/jquery.dataTables.min.js"></script>
<script async src="https://pagead2.googlesyndication.com/pagead/js/adsbygoogle.js?client=ca-pub-5890139232703369"
 crossorigin="anonymous"></script>
			<div class="col-md-6 col-lg-5">
				<div class="login-box bg-white box-shadow border-radius-10">
					<div class="login-title">
						<h2 class="text-center text-primary">Welcome To LeavePortal</h2>
					</div>
					<form name="signin" method="post">
						<div class="input-group custom">
							<input type="text" class="form-control form-control-lg" placeholder="Email ID" name="username" id="username">
							<div class="input-group-append custom">
								<span class="input-group-text"><i class="icon-copy fa fa-envelope-o" aria-hidden="true"></i></span>
							</div>
						</div>
							<input type="password" class="form-control form-control-lg" placeholder="**********"name="password" id="password">
								<span class="input-group-text"><i class="dw dw-padlock1"></i></span>
							</div>
						</div>
						<div class="row pb-30">
							<div class="col-6">
								<div class="forgot-password"><a href="forgot-password.html">Forgot Password</a></div>
							</div>
						</div>
						<div class="row">
							<div class="col-sm-12">
								<div class="input-group mb-0">
								   <input class="btn btn-primary btn-lg btn-block" name="signin" id="signin" type="submit" value="Sign In">
								</div>
							</div>
						</div>
					</form>
				</div>
			</div>
		</div>
	</div>
</div>
<!-- js -->
<script src="vendors/scripts/core.js"></script>
<script src="vendors/scripts/script.min.js"></script>
The error clearly says that the file you’re trying to include() doesn’t exist. Send screenshot of includes folder. Also when including something important, use require() instead of include()
The error you’re seeing indicates an issue with the server’s session storage.
But I just checked your website and it seems to be working now. So it seems the issue was already resolved.
Problem solved i have added
ini_set(‘session.save_path’,realpath(dirname($_SERVER[‘DOCUMENT_ROOT’]) . ‘/tmp’));
to my session.php file
but now i facing new issue with this hosting
I have implemented send email after form submit but mail dint sent
attached mail function
please help why mail dint sent
Due to this
Email is restricted on free hosting
You can try this
i want to send mail from outlook to outlook accounts.
how this will be done
You need to find out the smtp credentials
You may be hit by rate limit as well. Good luck!
