its not set to this
what should i do now?
Edit the value? Double click on it and edit it.
why should i edit its already correct
Do you have Multisite enabled on your website at all? Because if so, the setting may be located elsewhere, judging by this forum post:
I donāt know enough about WordPress to say where this setting is exactly. But the Cookie Domain for your site is clearly wrong, and I donāt know for sure where to set it.
yes its multisiteā¦Checking this out
I made this mu-plugins file and inserted the codeā¦
Still not working : (
Though, I really appreciate your effort @admin
i think i should raise a query in wp forum only
THis has become a bit complex now and ig only wp enginners can understand
umm isnt this for kinsta specifically?
The ftp methodā¦
i would find logs file in htdocs?
Its the only folder where your files exist.
where is that folder⦠āRootā means htdocs?
Of course. are you asking for real?
i am asking because i cant see that there
only 4 folders
Sorry, you need to set up logs before, not sure how that will help you now after enabling it now:
done still not showing
