I have hosted my domain form infinityfree 3days ago and after set upping nameserver, wordpress software and after waiting 3 days yet I am not able to access my wp-admin website not online yet
plz help
waiting for your responce
What is your website URL, so we can help you?
http://ultimatetech.club is my website plz help and respond fast
waiting for your respounce
For me only the www version works, but the non-www version redirects to ads, so it seems like some DNS records are corrupted. Can you try to remove and re-add the domain from the “Addon Domains” section of the Control Panel, then re-install WordPress with Softaculous App Installer on the new domain’s htdocs path? That may fix the issue.
ok i try
for how much time you will be online?
can I have your contact no. to contact you plz help ?
I connect sometimes to the forum, but I will be always there.
I’m not Indian, and don’t know if your plan supports international calls, so I can’t give it to you.
My other website with same hosting which is http://ultimateurl.in is online yet it also showing same message as http://ultimatetech.club and yet ultimateurl.in was hosted 1 day later then the hosting of ultimatetech.club
This will solve all of your question / problems:
https://infinityfree.net/support/why-doesnt-my-domain-work/
should I change my hosting
One more problem my not able to upoad URL SHORTENER script in my website should i change hosting for my both website ?
I see your domain name is currently using Cloudflare’s nameservers, and the Cloudflare nameservers don’t have any DNS records for your domain to allow it to serve your website.
Please try to fix your DNS records in Cloudflare first. If you don’t know how to manage your own DNS records, please consider moving your domain name back to our nameservers.
