Hello Admin,
I have first added the free infinity and then added a custom domain, linked from a domain provider. I had wp installation but now none of the websites work…
Please do not hijack posts.
If you need help, please at least share your website URL.
Hello,
Sorry did not mean to, I am new to this.
I have created free domain and tried installing wp org, which worked and I am able to use it. Then I have tried adding a custom domain mariamikaela.com, but wp does not reflect a custom domain, something I do wrong here.
Read
I also split up the topic for you. @Mariamikaela, this is your first and last opportunity; if I see you stalk an existing topic again, your post will be flagged and removed.
Thank you, noted.
I have tried various solutions from this article, then deleted and reinstalled wp on a different domain, I just feel not capable of doing it, giving up. Thank you for the link and fast response.
Maybe I try from scratch by creating an account.
If you have a basically new website, you can just remove the old installation and install a new copy of your website on the actual domain.
Creating a new account is probably not helpful. In either case, you’d need to setup a new website or migrate an existing website, and also migrating the domain to a different account just slows things down.
For next time, if you want to host your website on a custom domain, then it’s easier to add the domain first and install the website to the right domain right away than it is to first install the website on a subdomain and add the domain afterward.
