no puedo instalar wordpress error de base de datos
no puedo conectarme a la base de datos para instalar wordpress, ya modifique los archivos wp-config-php con los datos de la base de datos pero no funciona
@martyslave said:
I can not connect to the database to install wordpress, I already modify the wp-config-php files with the data of the database but it does not work
First of all, this is an English language forum. You’re not very likely to get an answer to your question if most people here can’t read your it.
From the sounds of it, you’re not using the correct database credentials. Please double check your details. Additionally, you may want to enable debug mode through the WordPress config to get the real error message and then compare it to the errors here: https://infinityfree.net/support/common-mysql-errors
