I want to create a website. But the problem is every time i install wordpress it creates example.com/wp/wp-admin.
But i wanna create example.com/wp-admin.
What should i do now
This wp indicates the path to wordpress script. In you case, the scripts are installed inside wp directory/folder.
I’m half forget about everything inside Installation script (if you download it via official site), but I’m pretty sure there is a text field that determine your installation directory.
If you install it through Softaculous, I’m afraid I am in no help, because I don’t have experience in that app.
You should set the installation directory to “”, instead of “wp” while you installing it
Thank you. That was a great help. But i am having problem with loading speed. Any suggestions how to increase speed
Cloudflare caching?
Use Cloudflare catching and optimize your images. Look you on youtube on how to optimize WordPress images. There are also wp plugins to optimize speed and make sure to use a speed testing took to check your speed so you know what works and what doesn’t.
