At the moment I haven’t had any issues with hosting my site though I am upgrading my site pretty soon to an MVC system.Can I create folders and files outside the HTDOCS folder?
You cannot, however you can upload the content of an MVP application then create a .htaccess file inside the htdocs folder and put this in it (this one if for Laravel):
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteRule ^(.*)$ public/$1 [L]
</IfModule>
I have not used Laravel.Is there anything else I can do?
The solution I provided can work for most of MVP applications, you need to modify what I provided a little depending on what the application’s root is named (e.g laravel uses public as root directory)
