Need help renewing my ssl certificate for my site made on Google Domains
openmusic.info
SSL certificate expired today and I’ve been having difficulties getting it renewed. I have my Google Domains dashboard, my account on infinityfree. What steps do I need to take? Should I go to epizy name servers or stay on google’s? Not sure what I’m doing wrong.
Stay on google nameservers. Just add the records from the infintiyfree client area.
Welcome!
Just follow this guide:
When you get to the CNAME section, you will create them with Google.
I went back and forth on this step in my confusion, not sure if it was undone last.
But the website appears to have the renewed certificate at least.
Please check the instructions in the client area. It checks which nameservers are in use and where you need to add the CNAME records.
And if you added the records but it didn’t work, then please also remember that changing DNS records can take some time to take effect. Usually it’s less than 30 minutes, but it can take as long as 24 hours.
