Need help I am facing inode usage problem and two other issue
How to reduce inodes in 2023
AmanBrand.great-site.net
I facing issue
Help me. I tried to resolve please infinity free help I had done daily workhard
How to reduce inodes, there is issue of class.wp-duotone.php
Inodes are nothing but number of files and folders…
If u want to reduce inodes then dlt some files
How to do ? Give me WhatsApp number
You go into your file manager and delete some files that you no longer need.
https://amanbrand.great-site.net
Warning : require(/home/vol15_8/infinityfree.com/if0_34689642/htdocs/wp-includes/class-wp-duotone.php): failed to open stream: No such file or directory in /home/vol15_8/infinityfree.com/if0_34689642/htdocs/wp-settings.php on line 178
Fatal error : require(): Failed opening required ā€˜/home/vol15_8/infinityfree.com/if0_34689642/htdocs/wp-includes/class-wp-duotone.php’ (include_path=ā€˜.:/usr/share/pear/’) in /home/vol15_8/infinityfree.com/if0_34689642/htdocs/wp-settings.php on line 178
There has been a critical error on this website.
Help me this issue showing in my website and i did not not where i can reduce inode under file manger .There is no option in file manger to reduce inode. help me please
Did you delete the class-wp-duotone.php file?
it already deleted. class.wp-duotone.php is missing
Of course there’s no option called ā€œreduce inodeā€, because that’s not a thing.
In order to reduce inode, you have to delete files. Can you show me what plugins you have been using right now?
i already tried by renaming plugin but still i facing issue
option not available
Renaming plugin does NOTHING AT ALL.
Please DELETE them, not just disable or rename them.
If you don’t understand what is an inode, please read:
In short:
Every file and folder is an inode.
Just delete them. As I told you in your second topic:
Keep in mind that this is not an automated process, you have to think and decide what files you need and what you don’t.
If you have trouble in deleting the files with online file manager, try using filezilla:
hello sir i had delete multiple files but still showing same error as well as why showing class.wp-duotone please help me personally .
i deleted more 15 files but it still same problem
First all, 15 files do very limited impact.
The number of files you deleted should be around 500+ to have some effect.
Also, make sure that you have reinstalled the plugin, as that file doesn’t exist in the first place — reducing inodes only make it possible to install the plugin, but doesn’t fix the issue immediately.
Please refer to my reply in your another post:
if my i reistall wordpress then will my all data will clear ?
First of all, you only need to reinstall the plugin / theme, not the whole wordpress.
Secondly, if you backup your wp-config.php in your website folder, and copy that back into the new install, then you don’t probably lose your data. (Unless you deleted your database…)
unable to fix this problem ca you help me persoanlly
Please backup your website
Then reset your hosting account
This should clear your inode issue.
Reply to this once done
