https://gamactiogames.page.gd/
ERR_CONNECTION_TIMED_OUT
today, i was experimenting with my other website, then, it affected other websites, such as this, its down now
Does check-host.net show your site as down from most locations, or only from your own connection? That tells us whether the problem is on your side or on the server.
ERR_CONNECTION_TIMED_OUT means your browser couldn’t set up a connection to the server at all. It isn’t an error from your website’s code, so something you changed on your other site shouldn’t cause it directly. Our article on this error says the block is usually in one of three places: your device, your network or provider, or the hosting servers blocking your IP address. It also says server IP blocks typically expire on their own within 24 hours.
Here’s the first check from the article:
Go to check-host.net, enter https://gamactiogames.page.gd/ and click HTTP. If most locations fail, the site or its server is having a problem. If most show OK, the block is between you and the server. In that case, try the site on your phone using mobile data instead of Wi-Fi.
Your hosting account for this site shows as active. It isn’t suspended.
Please post the check-host result and whether the phone on mobile data can open the site. I can then point you to the right next step.
i tryed this on my phone, it dosent work on my phone too. this message says that the conexion of this site isnt secure
i viewed and says connection timed out
The servers are currently down, please read the status page.
me too ermm
it now works, thanks
