Nameservers verification problem
wooshcraft.ml
i already linked my nameservers few days ago and still waiting, it is said in domain infos that i already linked it, it seems the problem is here in the system of infinityfree
Validation error
An account setup is already in progress for you. Please try again in a few minutes.
Validation error
Your domain is not yet pointing to ns1.epizy.com and ns2.epizy.com. Change your nameservers at your domain registrar and wait a few hours. You can also create an account with a subdomain first.
Correct they are not pointed yet. Check with freenom, best of luck with that!
@anon39162748
add ns https://my.freenom.com/knowledgebase.php?action=displayarticle&id=3
There are some online suggestions about Freenom and DNS problems
( if problems are confirmed with some tools! ) to force Freenom DB to be updated/refreshed
the first is to go into Freenom settings
and return to their default NS and wait 6h
then put the custom NS back and wait at least 30min-24h
the other is to delete the domain from their system and then add it again
after that config. custom NS and then wait at least 30min-24h
