Nameservers/A-records
Hi @KangJL and @Admin
Thankyou both for all your help so far, after chatting on that article linked above, I have created a new account with the same domain and updated goDaddy domain details like we did before. My issue is that this new account has been created for over 72hrs and I get one of three things happen when I go to the website…
1 - It works as it should
2 - I get this domain is parked by goDaddy page
3 - I get this error message - sometimes clearing my cache/cookies fixes this one othertimes it doesnt…
Can you please help me fix this so I can actually have a working website :joy:
Your site’s loading fine for me, except for maybe your logo :joy:. This sounds like a DNS caching issue, try flushing your computer’s DNS cache and clear the browser one as you mentioned and see if it persists. Keep in mind it can take up to 72 hours for everything to work properly, though.
Thats funny cause I just tried again and this is what I see now (completely different to 1 hour ago when I posted that last screenshot)
Nameservers are incorrect, please check your regirar.
What should they be? I thought I can use GoDaddys default nameserver without issues?
Your A record for the new hosting account will most likely be different.
You can. However, you will need to modify your A record.
Did you point the A record to 185.27.134.143?
Yes I did this, please see the picture below for reference
This is what I see
Something seems wrong with you dns entry
I believe your issue was caused by the second IP on the A record
Ok so how do I correct this issue?
Do I create a second entry with the second IP address 34.102.136.180 like I posted here?:
No, this is precisely the cause of your saga. In fact you should try to remove this entry
You have to review your dns entry.
Look out for any CNAME or A record which may be causing this.
Would either of the two below be causing my issue, I cannot see anything that has that IP address written anywhere, how else could it be displayed or what else should I be looking for?
This is the likely culprit
Please remove this A record
I have removed this now and used a DNS checker which has reported back the below
I will report back if I continue to encounter issues :slight_smile:
Thankyou for all your efforts!!
Looking good now
