Nameserver failed for 5 days
Hey,
so I’m trying to add a costum domain to the website (http://Heimatplanet.infinityfreeapp.com)
For days I am getting the same error: Please verify your domain name!
Please choose only one, you cannot use both methods at the same time.
I checked on several DNS-tracking websites, all are showing me the requested ns1./ ns2. servers - my account is an ifO account, so this should also be right.
I cleared the DNS settings of my windows laptop, restarted the internet and tried it with a new infinityfree account.
Any ideas how i can make infinityfree to do anoter check on the Nameservers or other ways I can make it work?
thanks
Just need a little bit of information (or screenshots) just to help fully understand the error and help you :slight_smile:
So your custom domain, who’s the registrar you got the domain from?
can you take a screenshot of the name server settings for the domain?
and can you take a screenshot of the exact error message your getting just so we can see where it is ect?
thanks
–edit–
Oh and welcome to the forum :slight_smile:
Thanks Dan :slight_smile: , so the registrar is ionos.de
I registered the new nameservers on sunday, since then it still shows up the regular (old) settings of ionos… I checked it on nslookup and dns checker, both were updated til tuesday.
Likely due to this
Please do this instead
Alright guys, thanks a lot.
I alredy verified with CNAME, so now i changed the nameservers at Ionos again.
Hopefully it will work out within the next days, otherwise I’ll be back soon :wink:
This will likely not work.
Do this instead
Thanks again, thats quite complicated. I’ll try another solution and might come back in a while.
