Nameserver and .it domain
Hi,
I’m trying to setup an Italian domain, (.it) and I can’t, cause I don’t pass nic tests (nic is the Italian Autority), could you help me?
Thank you, Dave
Not really, especially since you haven’t included any information about which tests you cannot pass in the first place.
But it sounds like something similar to this: https://infinityfree.net/support/unable-to-set-nameservers-dns-query-refused/
Thank you!
Yes, it seems to be the same case, registrar fails check, now is mandatory for .it domains (you can see it on http://dns-check.nic.it) so I have no possibility to setup my first domain Bellacanzone.it,
Thank you, I will try again
Dave
Hi,
I see there are a lot of posts about this error, for example: https://forum.infinityfree.com/discussion/1208/can-not-set-nameservers-for-my-lu-domain-since-the-test-fails-dns-lu
there is a way to confirm domain that permits me to configure name server? mh… I don’t konw, maybe like postponing the check after a confirmation,
please, help me,
Thank you a lot
Davide Del Medico
Yes: plug the nameservers in your domain registrar’s panel. If it works, it works. If it doesn’t let you, then it doesn’t work.
