Mywebsite.gq have ssl but mywebsite.gq/blabla not have ssl
my website have ssl certificate but my website with /result have not ssl certifiate. i need help pls thanks
Please fill out the template to get help.
What is your URL?
https://jsearch.gq. but without the ssl is jsearch.gq/result. (Yea it a search engine i made)
Works for me. What happens when you try to load that page over HTTPS?
Also, since it is just Google Search (GCS), you can’t claim that it is tracker-free, because Google is still tracing everything that is done via JavaScript.
made a search in the search box. after, it redirect to jsearch.gq/result but in http. In http, the website is a little broken, but not in https. Do you have it or not
Maybe this would help
i do this. made a search in the search box. after, it redirect to jsearch.gq/result but in http. In http, the website is a little broken, but not in https. Do you have it or not.
Do you read? Use https not http.
Read the link I posted
As @Greenreader9 said
I want it to do it automatically.
jsearch.gq have automatically the ssl, but not jsearch.gq/result
Like I said, most likely you did not do this
The page https://jsearch.gq/result/ is working with HTTPS for me, but I do get a warning because of Mix Content. That’s because if you want a truly secure page, then ALL links and assets on the page must use HTTPS.
But the images in the footer of the page use URLs starting with http://, not https://, which is why you get this warning.
This means that your SSL certificate and installation are correct, this is an issue with your website code or configuration.
