MySQL issues
epiz_30332396
I dont see any error message, ive transfered the php files over from xampp to here. I’ve set up the database and i can retrieve data from the database but cant write data(using pdo prepare etc) I know the code is fine, has i used it on xampp(of course i changed the DB connection info lol)
URL? Specific page that is not working?
We all want to help you, but “I can’t write data to the database, but it works fine on my machine” doesn’t give us a lot to go on.
Here is some information that could help:
  • Can you share example code?
  • Do you check whether the query executes successfully (many snippets we see here don’t check the results of the query/execute function or don’t retrieve the error)?
  • What is the error generated by the query?
  • Have you tried executing the same query in phpMyAdmin? Does that work?
