The script I’m using: Code Canyon’s MTDB video streaming script
the error i’m seeing is:SQLSTATE[HY000] [2002] Connection refused (SQL: select * from information_schema.tables where table_schema = forge and table_name = migrations)
Please help me or just tell me that is it solvable or not otherwise i have to drop this project ?
Relevant Info:
I have tried everything from deleting and recreating the database, deleting the script files and reuploading them, tried every DB host i thought of like infinityfree’s sql302.epizycom,127.0.0.1, etc.
What did you put as the DB hostname? On other hosts it’s normally local host, however on InfinityFree and other MOFH powered hosts you can find it in cPanel or the client area.
