MySQL databases not appearing after successful creation
https://rayzbusinessmanager.site.je
Subject: MySQL databases not appearing after successful creation
Hello InfinityFree Support,
I recently created a new hosting account (if0_43310890) for rayzbusinessmanager.site.je.
I’m experiencing an issue when creating MySQL databases.
  • The dashboard confirms that the database was created successfully.
  • However, the database list says “No databases found on this account.”
  • VistaPanel previously showed 2 databases in use, but none were listed.
  • phpMyAdmin does not display a database name and fails to open correctly.
  • I’ve tried refreshing, logging in again and using Incognito mode.
  • My website and PHP scripts are working normally.
Could you please check whether there is a database provisioning or synchronization issue with my hosting account?
Thank you.
Thank you.
Which name did the dashboard show for the database when it said it was created? Did you copy it, in the form if0_43310890_something, into a script, and does that script connect to MySQL right now?
I ask because the account if0_43310890 really does have no databases right now. So the empty list matches what the control panel shows, and the problem is that the creation didn’t stick. That also means phpMyAdmin has no database to open. If your scripts connect fine, they’re probably using a database from a different account, so it’s worth checking which host and database name they use.
The setup article describes how a new database should show up under Current Databases after you create it:
If the database name from the confirmation message is the same as the one in your script, tell me that and what the script’s connection error says, if it shows one. That will show whether anything is connecting to a database at all.
  1. Your account username is if0_43310681.
  2. Your MySQL hostname is sql209.infinityfree.com.
  3. The creation form closes, but no database appears.
  4. The page continues showing “No databases found on this account”.
I’m sorry for the delay in investigating this.
There was an issue with database server sql209, where databases on that server could be viewed by the members area or control panel.
The databases themselves still exist, and websites that were already set up could still use them, but viewing them in the members area or control panel did not work.
Creating databases also did not work, and any databases you may have attempted to create were not created, despite the panel saying the creation was successful. That issue is also resolved, so please try again now to create the database.
