My website keeps going down and saying unavailable
http://alagmuseum.wuaze.com/
This site can’t be reached
Check if there is a typo in alagmuseum.wuaze.com.
If spelling is correct, [try running Windows Network Diagnostics](javascript:diagnoseErrors()).
DNS_PROBE_FINISHED_NXDOMAIN
This site has been working fine since 2024. For the last several weeks it seems that it is down every day. I have tried republishing the site and checked domains and registrations. Everything seems the same as when it was working.
Seems to be working fine for me.
Have you tried it on a different network (such as mobile data) or using a VPN. It’s possible that your isp has recently had *.wuaze.com added to their blacklist.
Unfortunately happens from time to time with free domains
I checked from a different ISP and it appears to be working. I’ll try and contact my ISP and see if they will unblock it. Thank you for looking into it and getting back to me so quickly!
