My website is showing some DNS problem
Dear InfinityFree Support Team,
I am writing to report an issue with my domain awasthikaushal.com.np, which is currently not working.
It has been more than 48 hours, and when I try to open the website, I receive the following error: “DNS address could not be found (DNS_PROBE_POSSIBLE).”
Additionally, in my hosting account dashboard, I see the message: “Your domain name is not pointing to our server. Your domain name does not have valid DNS records set up.”
I would like to clarify that I have not made any changes to the nameservers. They are still set as:
ns1.infinityfree.com
ns2.infinityfree.com
Given this situation, I would appreciate your help with the following:
Identifying the exact cause of the issue
Guidance on how to fix it
An estimated time required for resolution
Please let me know if any action is required from my side.
Thank you for your support.
Best regards,
There’s an issue affecting .com.np domain names right now. All you can do is wait for the underlying issue to be fixed.
Also, please don’t use AI to write on the forum as it just makes things less clear than if you write your posts yourself. Thank you.
Okey sir thanks for your response. Please fix ASAP
Since this is a community forum, we can only wait for IFastNet to complete a fix
The DNS block has been lifted so website is start working again.
