I am getting this message, and so some servers block.
URL is progressives.scot - thanks!
You need to install a SSL certificate for your domain on either our servers or using Cloudflare with either the cPanel integration or dash.cloudflare.com.
Thanks. Where is the best place to obtain an SSL certificate? I tried to get one for the domain but struggled but the verification process.
Here’s A Tutorial For Obtaining A Free SSL Certificate By @Ergastolator1 :
Actually How Much Time Is The SSL Propagation Time Exactly?
At least a hour to up to 24 hours.
OK I have routed the domain through Cloudshare. Currently it is saying “Error Too Many Redirects” when I type in my URL when I try to open it. Do I have to delete or add something?
OK sorted using Really Simple SSL on WordPress ![]()
