My website buttons and animation not work HELP PLS!
BUTTONS and animation not move or work
(not move or work)
(using php and javascipt)
immediatly I can see a couple of errors you might want to look at:
still not work
Ok, so what are the exact symptoms of the problem your facing. What buttons and animations are you expecting.
End of the day we can offer guidence but we are not the experts on your website, you are the only expert for your own site.
every single button is not working when i click nothing happens every single button and example one button that start rolling animation not start or move at all and
When i press test spin button nothing happens but it should start javacript animation
Looking at your page source. I can’t see any script in there, or linked in a tag that would do that.
are you sure you’ve uploaded it, and referenced it correctly?
what source? problem is inside website nothing works except only few menu button to switch pages but nothing else is not working
why my website looks like this
We’ve already told you that you have not uploaded a complete website, you have a lot of missing files.
The source is just the source code of your website. Are you saying that you do not understand what does “source code” mean?
And asking the same question over and over again won’t fix the issue.
sry but i dont have missing files problem is why website look the way it look in picture
Prove it then. Screenshot your files, not just assume it.
Like I just said, asking the same question over and over again won’t give you a different answer or fix the problem.
if you think i have missing files then tell me what files is missing…?
When I check your website with the Network tab in my browser open, I see that the requests for the CSS and JS files respond with a 500 status code:
A 500 status code usually means the PHP code has crashed.
Having had a quick look at your website files, you do appear to be remapping all CSS and JS links to a PHP script to process them. This PHP script is probably crashing. You’ll need to fix that to make your website work.
I must also say that I strongly recommend against processing every file with PHP. Combining and minifying files is good practice, but that should be done once when you publish your site, not on every request. Any performance and resource usage benefit of combining and minifying is undone by the fact that there is now a PHP script processing files that should just be a static file load.
