Yet the Database exists and all the info is correct and ive even tried on another new DB and same thing idk how else to fix this so i can setup my website (sorry first time posting on here so if its in the wrong topic please by all means delete it or move it)
what’s your data? do you use localhost instead of 111sql.epizy.com?
edit: just a ninja’d x(
It doesn’t look like 111sql.epizy.com, but it should look like sql111.epizy.com.
yes i use local host
Then you must change it to what it should look like sql123.epizy.com, and can be found on the “Database Host” part of the table available on the “MySQL Databases” section of the Control Panel.
