my site qundeel.com is not working and facing following error
The server appears to be down, or your connection isn’t working as expected. Please try again later.
Hi and welcome back to the forum! Please don’t stalk existing topics; only create your own ones for the issue you’re having. I split it up for you; also, this is your first and last chance. Another violation I see will result in your post on the other topic being flagged and deleted.
As for your issue, I see a 500 error caused by some wrong rules on your .htaccess file (yes, it’s generated by the server and not by the browser), so you have to correct them or delete any wrong rule you see before your website can work again. If it still doesn’t work on your side, try the workarounds on this article:
Dear Sir
with reference to your previous reply, it is stated that i have removed the same but qundeel.com is still not working and displaying following error
500 Error, please check your php script / enable display_errors in your cpanel
Oops! Something went wrong.
Something prevented the page from being rendered. Please try again.
It doesn’t seem so; the .htaccess file you have to check is the one you have on your domain’s htdocs folder.
Please note that this error message is wrong. If you get this error, it actually means that your .htaccess file is invalid and could not be parsed.
