My website URL is:http://theartgallery.ga/wordpress/
**What I’m seeing is: This page isn’t working
theartgallery.ga is currently unable to handle this request.
HTTP ERROR 500
**I’m using this software:wordpress,chrome, Filezilla **
Additional information:
enable display errors from alter php config
Can you please list out steps how to do that??
go to your cpanel:
from SOFTWARE tag click on alter php config:
then choose your domain name and click on Alter PHP Directives. then change Display Errors to On.
hope it helps
Oxy
October 3, 2019, 12:32pm
5
@anon73157666 it would probably be better to uninstall and then install to the right location
why?
if you want to display WP with your domain ( http://theartgallery.ga/ )
without subdir “wordpress” in the address ( http://theartgallery.ga/wordpress/ )
then leave blank this field in the Softaculous installer.
Actually. My site is on offline folders and I uploaded the folders and imported the dataset so its no use.
Thank you for your response.
Thanks a lot … Now I can see my server errors so I’m managing the errors and hope it works properly soon.
Oxy
October 4, 2019, 5:13pm
9
@anon73157666
for now it seems that all you have left to do is download this FILE and put it in a newly created folder named framework
in this location
/wordpress/wp-content/plugins/form-maker/framework/ WDW_FM_Library.php
I see that your landing page still appears. Have you installed WordPress through Softacolous?
If you install it on the front page of the directory (/htdocs) then you don’t need additional folders like /wordpress and don’t have to use folders to install WordPress.
You can use the directory folder according to your taste to place where WordPress will be installed
