clementpabraham.in
note : I have tried clearing cookies…but it still the same error
Can you show me your .htaccess file?
BEGIN WordPress
The directives (lines) between “BEGIN WordPress” and “END WordPress” are
dynamically generated, and should only be modified via WordPress filters.
Any changes to the directives between these markers will be overwritten.
RewriteEngine On
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteRule . /index.php [L]
RewriteEngine On
END WordPress
Umm, can you put them in codeblocks?
Hmm, by any chance did you edit the file?
(I am not so great in htaccess rules, so probably someone will help you)
i have done cpanel integration with cloudflare is that the issue
hmm, maybe Try to disable Automatic HTTPS rewrites in CloudFlare
