My site www.omeralrekany.com doesn’t work, I had put nameservers
ns1.epizy. com
ns2.epizy. com
ns3.epizy. com
ns4.epizy. com
ns5.epizy. com
from infinityfree to my domain’ settings in Godaddy, waited 3 days, still the same problem, so I have installed the WordPress, still the same problem, when I install the WordPress, tried to use omeralrekany.com & www.omeralrekany. com but still the same problem.
Can anyone help me, please?
For me the version with www now works, but the non-www one does not. Try removing cache and cookies or configure 1.1.1.1 if you experience the same problem with the www version; configure the nameservers even for the non-www version.
The nameservers after a bit will be automatically configured to host the domain; like I said before, you need to wait some minutes or hours to the changes to propagate.
Try configuring 1.1.1.1 on your computer/Phone. EDIT: I configured 1.1.1.1 but your site is running into an ERR_TOO_MANY_REDIRECTS Error. Try setting the SSL option from Flexible to Full, remove the redirect options to SSL via Cloudflare, uninstall the plugins that redirect to SSL and set the URL from the HTTP version to https via the wp-admin.
A properly configured WordPress doesn’t need any Plugin to work with https. Uninstall Really Simple SSL and set the URL from http to https in wp-admin. Login again if requested and enable “Always Use HTTPS” on Cloudflare settings.
