My site doesn`t load
My site is http://onlinestorecr.epizy.com
user is epiz_31123317
the page appears completely blank, apparently it is not selecting any file as the start index, I have already uploaded all the data to htdocs but it does not work.
thanks in advance
what kind of site you are building? html? or cms wordpress? if its word press i suggest, uninstall and install it again, as bad instalations may accur.
This is what I see…
This should help
HTML, apparently it was a php problem thanks
Yes, effectively it was php problem thanks
Why are you using PHP, Try java.
InfinityFree doesn’t have Java support. Only PHP and HTML works here.
