An error occurred during a connection to infagames.infy.uk. SSL received a record that exceeded the maximum permissible length.
And if i go in advanced
What makes the site look dangerous?
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
What can you do about it?
Please contact the website owners to inform them of this problem.
Learn more about secure connection failures
Error Code: SSL_ERROR_RX_RECORD_TOO_LONG
sometimes i get this error in chrome, if i go in http://infagames.infy.uk it fixes the problem and swaps to https without problems
Google Chrome notably caches SSL certificate, and as far as I know, there is no way to clear that cache. Try checking the website in Incognito Mode, if you don’t get the error there, then I’m 100% sure that its SSL cache.
