My InfinityFree Subdomain Returns DNS_PROBE_FINISHED_NXDOMAIN – sigmaqrfeedback.infinityfreeapp.com
http://sigmaqrfeedback.infinityfreeapp.com/
Hello InfinityFree Support Team,
I am experiencing an issue accessing my website:
Domain: sigmaqrfeedback.infinityfreeapp.com
Hosting Account: if0_42106964
Hosting IP: 185.27.134.116
My website is returning the browser error:
I have checked the domain using different DNS resolvers:
  • Google DNS (8.8.8.8): resolves correctly to 185.27.134.116.
  • Cloudflare DNS (1.1.1.1): resolves correctly to 185.27.134.116.
  • My default DNS resolver: returns a DNS request timeout.
I have also flushed the local DNS cache and tested the website on another computer, with the same access problem.
My InfinityFree control panel shows that the hosting account is Active and the domain is associated with IP address 185.27.134.116.
Could you please check whether there is any DNS, domain or server-side issue affecting my subdomain?
I would appreciate your help identifying the cause.
Thank you!
Additional information from my InfinityFree control panel:
I checked the hosting account’s Overview page and found the following information:
  • Hosting account status: Active.
  • Domain: sigmaqrfeedback.infinityfreeapp.com
  • Hosting account username: if0_42106964
  • Assigned IP address: 185.27.134.116
  • Website directory: htdocs
  • Domain creation date: June 5, 2026.
The control panel’s Health Check section currently displays:
“No problems were found!”
However, the website remains inaccessible and I still experience the DNS_PROBE_FINISHED_NXDOMAIN error.
On a previous check, the control panel also displayed a warning stating that no index file (index.php, index.html or index.htm) was found in the htdocs directory.
Could you please verify whether the domain is correctly configured and whether there are any DNS or server-side issues affecting it?
Unfortunately, I am unable to attach screenshots to this forum post, so I am providing all the relevant information here.
Here’s a short summary of this post, so people can quickly see what it’s about. Please keep posts short and to the point: describe the problem and include the exact error message and your website address. That helps people help you more quickly.
  • My subdomain sigmaqrfeedback.infinityfreeapp.com returns the browser error DNS_PROBE_FINISHED_NXDOMAIN.
  • Hosting account if0_42106964 shows as Active with IP 185.27.134.116. Google DNS (8.8.8.8) and Cloudflare (1.1.1.1) both resolve the domain to 185.27.134.116, but my default DNS resolver returns a DNS request timeout. I flushed the local DNS cache and tested on another computer, same problem. The Health Check says “No problems were found!”, though a previous check warned that no index file (index.php, index.html or index.htm) was found in htdocs.
  • Could you please check whether there is any DNS, domain or server-side issue affecting my subdomain, and whether the domain is correctly configured?
Your own tests point at your default DNS resolver, not at the subdomain. Google and Cloudflare both return 185.27.134.116, so the record exists and resolves. Your default resolver is the one failing, and it’s timing out instead of answering. Chrome shows that timeout as DNS_PROBE_FINISHED_NXDOMAIN.
I couldn’t find a knowledge base article or answered topic that explains it for our subdomains. Other recent topics describe the same pattern, where a site opens with Google DNS but not with the default one, and none of them has an answer I can cite.
Two things would help narrow it down:
  • Does the site open from a completely different network, such as phone mobile data instead of your home Wi-Fi? If it does, the problem is your router’s or ISP’s resolver.
  • Who is your ISP or mobile carrier, and what does nslookup sigmaqrfeedback.infinityfreeapp.com print when you run it without naming a server?
As a quick check, set your computer’s DNS to 1.1.1.1 or 8.8.8.8 and reload the site. If it opens, that confirms the default resolver is the cause.
I think this article applies to your question:
Can you please try the troubleshooting steps from the article to see if you can find out more about why your domain is not resolving for you?
Hello,
Thank you for sharing this documentation.
I have followed the recommended troubleshooting steps and obtained the following results:
  • DNSChecker shows successful resolution worldwide.
  • Cloudflare DNS (1.1.1.1) resolves my subdomain to 185.27.134.116.
  • Google DNS (8.8.8.8) also resolves it correctly.
  • My router’s DNS server (192.168.100.1) successfully resolves my custom domain www.pginformatica.com.py, but times out when resolving sigmaqrfeedback.infinityfreeapp.com.
  • The website is accessible through an external HTTP checker, which returns HTTP 200.
  • The browser consistently displays DNS_PROBE_FINISHED_NXDOMAIN.
Country: Paraguay
Hosting provider: InfinityFree
I have tested using both Wi-Fi and mobile data, with the same result.
My main concern is that this issue affects not only my own access, but potentially other visitors using affected DNS resolvers.
Could you please help investigate whether this free subdomain is being filtered or blocked by any DNS providers or ISPs in Paraguay?
I understand that changing DNS settings on my devices would only be a workaround for me. I would like to find a solution that makes the website accessible to all visitors.
Thank you for your assistance.
