- Website URL:
senex.ct.ws - Issue: I cannot access my site from my home Wi-Fi, but it loads fine when I use Mobile Data or a VPN.
- Blocked IP Address: 112.134.237.33
- Request: Can you please check if my IP address is blocked by your firewall and remove the block.
Further, this web site is just for my personal use and feels like it is behaved well within the InfinityFree free hosting limits.
It works fine with mobile networks and even with WiFi when VPN is turned ON.
Once Admin is on, he can take a look to see if your IP is blocked.
If it is, it’s likely that its actually a range of IP’s that have been blocked, due to suspicious traffic. Unlikely anything that you’ve done, and most likely others (possibly even without their knowladge) with the same ISP.
In the meantime, it is worth checking if your ISP are blocking the .ct.ws domain. It happens annoyingly often.
I have had iFastNet check it, but they stated that your IP address is not blocked on your end.
Can you please tell us what exactly you see when you try to access your website? It’s possible that it’s blocked by an antivirus scanner, firewall or other “security” filter that may be blocking access to our hosting.
