I checked dnschecker to see if the name servers were changed.
While GoDaddy indicates that I successfully changes the nameservers to ns1,byet,com, The DNS checker says its nameserver is ns4,afternic,com and ns3,afternic,com
It looks like the nameservers are indeed still pointing to afternic.com.
Are you sure that this is the domain name you own? The WHOIS output shows that easybeez.com is currently owned by some domain broker.
If it is, please check with Go Daddy why your domain name shows this status. Only they can make sure that the nameservers you submitted to their panel are passed on to the registry.
I also checked the WHOIS information for that domain and, as I can see, I think that domain belongs to somebody else, and not you. Are you sure you registered your domain? If you didn’t register it, you can’t add it into an account unless somebody else changes the nameservers to those ones.
