Sebuls
January 10, 2024, 3:21pm
1
sebul.sarang.net
http://sebul.sarang.net/q2a/ login not work
Hi and welcome to the forum! After I tried to input some random characters in two fields, I get a HTTP ERROR 500:
When trying to access your website, you may see a page which returns the status code “500”. In Google Chrome, you’ll see a page with the error code HTTP ERROR 500.
There are typically two reasons which can cause this error:
The PHP code has crashed.
The .htaccess file contains invalid rules.
Here are some things you can try to debug and fix this.
Fixing crashing PHP code
A HTTP ERROR 500 simply tells you that the PHP code has crashed, but gives no information as to why it has crashed.
Gett…
Sebuls
January 10, 2024, 3:59pm
3
Hmm. I deleted .htaccess but same error occur. How can i solve it?
The problem is not the .htaccess file, since the error is generated by the browser itself; you’ll have to enable Display Errors by following the “Fixing crashing PHP code” part of the article I sent you.
Sebuls
January 12, 2024, 3:11pm
5
I upgraded my q2a software and my site sebul.sarang.net good.
Thanks.
Sebuls
January 12, 2024, 11:07pm
6
http://sebul.sarang.net/3/
I describe to Other information.
[ZaHE3k1b6l3DuKCvjHTXxQAAABY] /3/ mysqli_sql_exception from line 110 of /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/rdbms/database/DatabaseMysqli.php: Access denied for user ‘fceu_18338360’@‘192.168.0.51’ (using password: YES)
Backtrace:
#0 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/rdbms/database/DatabaseMysqli.php(110): mysqli->real_connect(string, string, SensitiveParameterValue, string, NULL, NULL, integer)
#1 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/rdbms/database/DatabaseMysqlBase.php(120): DatabaseMysqli->mysqlConnect(string)
#2 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/rdbms/database/Database.php(272): DatabaseMysqlBase->open(string, string, string, string)
#3 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/rdbms/database/DatabaseMysqlBase.php(91): Database->__construct(array)
#4 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/rdbms/database/Database.php(390): DatabaseMysqlBase->__construct(array)
#5 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/rdbms/loadbalancer/LoadBalancer.php(845): Database::factory(string, array)
#6 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/rdbms/loadbalancer/LoadBalancer.php(677): LoadBalancer->reallyOpenConnection(array, boolean)
#7 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/rdbms/loadbalancer/LoadBalancer.php(569): LoadBalancer->openConnection(integer, boolean)
#8 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/objectcache/SqlBagOStuff.php(190): LoadBalancer->getConnection(integer)
#9 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/objectcache/SqlBagOStuff.php(271): SqlBagOStuff->getDB(integer)
#10 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/objectcache/SqlBagOStuff.php(249): SqlBagOStuff->getMulti(array)
#11 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/objectcache/SqlBagOStuff.php(245): SqlBagOStuff->getWithToken(string, NULL, integer)
#12 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/objectcache/CachedBagOStuff.php(56): SqlBagOStuff->doGet(string, integer)
#13 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/libs/objectcache/BagOStuff.php(185): CachedBagOStuff->doGet(string, integer)
#14 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/session/SessionManager.php(936): BagOStuff->get(string)
#15 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/session/SessionInfo.php(150): MediaWiki\Session\SessionManager->generateSessionId()
#16 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/session/SessionProvider.php(171): MediaWiki\Session\SessionInfo->__construct(integer, array)
#17 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/session/SessionManager.php(268): MediaWiki\Session\SessionProvider->newSessionInfo(NULL)
#18 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/session/SessionManager.php(242): MediaWiki\Session\SessionManager->getEmptySessionInternal(WebRequest)
#19 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/session/SessionManager.php(192): MediaWiki\Session\SessionManager->getEmptySession(WebRequest)
#20 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/WebRequest.php(735): MediaWiki\Session\SessionManager->getSessionForRequest(WebRequest)
#21 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/session/SessionManager.php(128): WebRequest->getSession()
#22 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/Setup.php(759): MediaWiki\Session\SessionManager::getGlobalSession()
#23 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/includes/WebStart.php(137): require_once(string)
#24 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/3/index.php(40): require(string)
#25 {main}
