My CNAME is not working
what to check ?
Now the error is generated by the browser again, so Display Errors is off again! Maybe the rules applied inside the .htaccess file (the ones that the “Alter PHP Directives” thingy did) interfered with what you had inside the .htaccess file of the software (if there is one).
ok. is there any way to upload the zip directly to the hosting.
use ftp client also i could not upload upload the zip that was of 22mb
There is no way you can upload the ZIP file directly to the hosting, as it weighs 22 MBs and it exceeds the file size limit of 10 MBs, which is explained in this article:
And if you succeeded in uploading it even by splitting it, you couldn’t extract the files using the Online File Manager as it takes too much (and doing so will also increase the load on the server where it’s hosted). That’s why you had to extract it on your computer first, then using FileZilla upload the files.
