I do not know how to compress the size of htaccess, my CMS has a minimum size of htaccess of 10.9 KB more text can not be removed from there, you can learn how to solve this problem or compress htaccess my site is vkinete.ml
There is hardly ever a reason why a .htaccess file needs to be so big. Most CMS can do just fine with a .htaccess file of only a dozen or two lines.
Reducing the .htaccess file size is not really about compressing it, but more about optimizing the rules so you can do more with less rules. I did a fairly in-depth analysis for this person before, maybe the tips given there help you as well:
That said, if your software really needs such a massive .htaccess file, then maybe it just isn’t possible to host it on free hosting.
